Yes but its happening to this post at least after all the relevant information!seems like the same is happening here on the forum that is happening to the country, the rights of the one are stepping on the rights of the many. going to hell in a bucket.
ing just like in whoring real life is one of the oldest professions on the internet! (since it went to the general public.)It was hard but we held offYes but its happening to this post at least after all the relevant information!
lets us know how you make out if ya can fix it or going your other route
Once you have it apart post a pic, I just guessed it might have fried. Won't know till you take it apart. So we may have more relevant info after further detail.Yes but its happening to this post at least after all the relevant information!
You have to realizeing just like in whoring real life is one of the oldest professions on the internet! (since it went to the general public.)
business first, thenNothing wrong with having fun along the way
ing.
Update - No pics yet but it looks like the low fuel light isn't working any more either. drained the tank and the light isn't coming on when I turn on the key like it normally would if I was low on fuel.Well the dog is running strong (no tach still even after reset). Took a little loop to use up some gas since I have to pull the tank anyway (got a new fuel filter/regulator/fuel pump) to install. Updates to follow, likely tomorrow.
That brings up a good point...does any lights work? If the tach ring is blown no lights will work, no neutral, oil or high/low. Are all out?Update - No pics yet but it looks like the low fuel light isn't working any more either. drained the tank and the light isn't coming on when I turn on the key like it normally would if I was low on fuel.
The check engine light, neutral, turn signal indicators are working so power is good to the board.That brings up a good point...does any lights work? If the tach ring is blown no lights will work, no neutral, oil or high/low. Are all out?
Not so, on the one I replaced, the neutral, oil and high/low worked.That brings up a good point...does any lights work? If the tach ring is blown no lights will work, no neutral, oil or high/low. Are all out?
Strange..okayNot so, on the one I replaced, the neutral, oil and high/low worked.
The short on the one I replaced was bad enough to trip a relay within the Rip 2 and keep the bike from startingStrange..okay
I figured it was all or nothing. Well looks like he is gonna have to pull it apart then ha
