john sachs
That sounds like putting a Band-Aid on a heart attack.Mien has always sounded like a sewing machine, so I went with a louder exhaust!
If you can find a shop to remove and re=install your heads, the repair done correctly, figuring on the high side, shouldn't be over $1200.00 with all new parts.Ok John so I took my 05 mastiff to new mechanic that said he had worked on several big dogs. He agreed with you that the valve guides are shoot and I need new rocker boxes and that the heads really need to be shaved down to perform the way they should. he said that big dog and TP rockers had an issue with geometry and that they do not ride or seat correctly. He said to repair correctly I am looking at 5-6k. Then he suggested just putting in another engine at about 7k so I would have a warranty. He said the last option was to sell and buy an HD, so that made me feel he may not want to do work. I was wondering if these numbers sound accurate, I love the ride and look of my bike.
Wow! I'm with @john sachs....redoing the complete top end including your heads with new valves and guides, a cylinder bore AND new pistons and rings and gaskets shouldn't be over $1200......it ended up being bad valve guides and trashed engine, costly problem. I wound up just putting a new 124" polished S&S in.
Wow, how do you it?it ended up being bad valve guides and trashed engine, costly problem. I wound up just putting a new 124" polished S&S in.
Wow, how do you it?
They did take ya in the rear end IMO. That bottom end you could bolt up 124 Jugs, pistons and heads and it should be considerably less expensive than an entire new engine.I sent back to S&S for manufactures rebuild and they told me motor was shot and not worth rebuilding as I drove until motor blew. This sounded like bullshit but it was S&S so I went with it. They only offered to ship new engine free for old engine. So I went with new engine and new clutch to handle added power, needless to say just about 10k when I got bike back. I took in the backend but have the bike back and running strong...
That is very possible.
That is very possible.![]()
Just my two cents, I had the same exact noise, turns out the valve guide was so worn the valve was moving almost half inch back and forth hitting the bridge in the center of the valves. be careful removing the guides. I cracked the fwd head and had to find a new diamond cut 117 head. no that wasnt hard to find at all lol...Adjust your pushrods.
Worn Valve Guides.... I bet a beer.On my 05 mastiff I recently starting hearing a tap from front top area of engine, sounds like load sewing machine when running. I had the rockerboxes check and only normal wear, pushrods check but appear to be fine, bleed down test was fine and bike runs great with 25-30psi of oil pressure. checked for exhaust leaks and head gasket and all seems good. Just looking for help or idea for what else I should check, running mobil 20-50 and no metal in oil when changed
I don't think that post before you was mean for you and with that said I think your battery, even though you say its new, is bad. Have the new battery load tested to see if its any good. It should not drop to 4vI am not sure why you say that, I try to post my findings. I obviously am not a mechanic so I come here looking for help.
Hey, I just figured that out.Yes that pat was not intended for you I quoted someone else
