Why would you piss money away on another set of adjustable p/rods ? If your original ones were adjusted properly(a bent one would show up by the way), they ARE NOT the problem. More than likely damage has started from the TP boxes on a S&S engine. Changing the rocker boxes IF damage has started won't fix the problem, just like wearing a condom after being aids infected won't further prevent the disease to yourself.I am going to have the pushrods changed to S&S quick pushrods. I already had them adjusted but maybe one is bent. I will keep you posted
Would you do a search on the site, you would find a lot of discussion about this. John does know his shit...Good point, can I just put s@s rocker boxes without many other changes or do I need to just go with the TP rocker box. What should I expect to have them done?
Seems to me that a proper tune, and an exhaust system that's not leaking would have fixed the popping problem.I want to mention this, or shed some light on something. I as well had a noise at the rocker box. I had gone through just about all that you can go through and didn't find a thing. To accept the fact from many "that this is normal" just didn't sit well with me. I build race engines for a living and a rocker noise, or a noise from the rocker box or valve cover is not normal. I figure that during the winter, I will just change out parts because I didn't physically see anything. As time went on, I dealt with other issues and one of those issues was the popping during de-accel with the throttle blade on the carb closed. I made baffles for the exhaust in my shop, and installed them. The baffles actually cured that rocker box noise. I didn't make them to cure the box noise, but it did. In building engines for a living, apparently what was occurring was combustion that was not completely in the chamber and apparently a portion of combustion was occurring in the primary pipe most closest to the head. The back pressure from the home made baffles kept the combustibles (fuel and air) in the chamber and didn't let a portion get out into the primary to ignite.
If I pull the baffles out, the noise will be back in the rocker box.
Glad to see the forum cops on the prowl. Nicely done.But I'll tell you even more than that. On our forum have a secret ... We all do the intro ... After that the bike was repaired ...![]()
I had 2 TP rocker boxed on S&S engine Dogs come in last year for builds. Customers said they were running good. This is what I found. The other one wasn't quite as bad, but it still was close. Valve seating in the aluminum beyond the seat insert. Half of the valve guide was worn razor blade thin.Again like original text, sounds like sewing machine on top end front of engine. Took to my mechanic and checked rockers, valves, pushrods and said all had wear but looked fine and no need to replace any. Also did pressure bleed down and everything was fine. One option is to take the new mechanic but I trust this mechanic so I'm not really sure where to go from here .
It's not leaking John. Please re-read what I had written.and an exhaust system that's not leaking would have fixed the popping problem.
I did, and that's why I mentioned that most popping noise on decel comes from a leaking exhaust system or improper tune.It's not leaking John. Please re-read what I had written.
Ok John so I took my 05 mastiff to new mechanic that said he had worked on several big dogs. He agreed with you that the valve guides are shoot and I need new rocker boxes and that the heads really need to be shaved down to perform the way they should. he said that big dog and TP rockers had an issue with geometry and that they do not ride or seat correctly. He said to repair correctly I am looking at 5-6k. Then he suggested just putting in another engine at about 7k so I would have a warranty. He said the last option was to sell and buy an HD, so that made me feel he may not want to do work. I was wondering if these numbers sound accurate, I love the ride and look of my bike.I had 2 TP rocker boxed on S&S engine Dogs come in last year for builds. Customers said they were running good. This is what I found. The other one wasn't quite as bad, but it still was close. Valve seating in the aluminum beyond the seat insert. Half of the valve guide was worn razor blade thin.
Unless you check valve stem to guide clearance, you'll never know.
John
