Hirter6Pack
Not Quite A Guru
Push in on them They should push in freely.If it sticking. How do I unstick it?
Yes sir. Positive to positive and negative to negativeJust curious, are ya hookin the jumper cables straightto both posts on the battery, or putting the neg clamp on a ground somewhere else? Seems that if it starts with jumpers, it's either a weak battery or a bad connection somewhere, and not the starter ( I think) I have been wrong a time or twelve!
Just for giggles, try hooking the jumpers straight to the pos cables with them disconnected from the battery, and with the neg jumper cable hooked to the ground bolt on the frame. Kinda take the battery out of the equation so ta speak. ??Yes sir. Positive to positive and negative to negative
I will check the draw on the battery when I try and start it. Then adviseWouldn't shock me if battery is shot it's happened before some members have gotten new dead battery's
Ju
Where can I find that?Stator wire fully seated? Been known to get knocked off on a rigid bike....
7.9 first time, the 9.4 the second timeWe really need to know what the battery reads while under load. Hook the multimeter to the battery while it's on the bike and hit the start button. While holding the start button, what does the multimeter read for battery voltage?
Fully seated
Just tested it again, 8.4 and 8.6 under load.We really need to know what the battery reads while under load. Hook the multimeter to the battery while it's on the bike and hit the start button. While holding the start button, what does the multimeter read for battery voltage?
This is connected to the from of the starter.
Last time it registered at 7.9 and 8.4How far does it drop when hit start?
Battery !!!Just tested it again, 8.4 and 8.6 under load.
About two weeks ago. When I know I'm not going to ride it for a few days I hooked it up to a tender. Then last week nothin. I jumped it and rode it around town. Started every time after that. Then the next day same symptoms.Ya might wanna do something about that ! How do the contacts inside the solenoid look ? They may need cleaned up. When wast the last time the bike started okay?
Those are low voltage readings. Depending on the electrolyte temperature of the battery during the load test, I would want to see 9.8-10.0 VDC minimum especially after a long charge.Just tested it again, 8.4 and 8.6 under load.
