Compu-Fire stator, rotor, and VR kit part #?
bikepoor
Hi, my 07 k9 quit charging and I determined that the stator is dead! WSW is down till July 15th or longer as the website states and though I can find the kits none list big dog specifically! Thanks
bigd1960
Have a bn vr and stator if u need. Purchased for my 07 as well.
bikepoor
wanted to give an update and say thanks for the help! i put the compufire 40 amp 3 phase on my K9 and it is working perfect! very easy install! i think it is awesome that guys on here are so willing to help and even offer their spare parts to get a fellow biker back on the road!
:old2: Thanks for the update
Since I installed the voltmeter on mine I can watch the volts as I ride and was wondering what the big advantage would be to go to the 3 phase? I have 13.3-13.5 at idle, and anytime I'm going down the road no matter what RPM's its running at 14.3-14.4 volts. Now I realize its not Amps, but does the 8 additional amps really make that much difference:oldconfused:
Not a lick. Only difference with 3 phase is at idle it's like 14v.
Extra amps are not needed on a big dog unless you got a stereo, heated grips and a bunch of other malarkey.
nosaj82
Hey Guys.
So I just installed my 40 amp on my 09 K9. Pretty easy task but I did not have to grind any tabs nor did I use any spacers and other parts that came in the kit except the rotar and stator.
Did I install this wrong or is it possible that's its pretty much plug and play?
Hey Guys.
Unless the bosses have been grounded down before the rotor wouldn't fit square without it. Actually I don't think you could get it on, unless you took off the inner primary as well.
pauly
I have the factory charging system in my Mastiff but changed the voltage regulator for single phase compufire (after the oem one burned out) and at idle it I got 14.2 volts.
Paul.
