Have a bn vr and stator if u need. Purchased for my 07 as well.Hi, my 07 k9 quit charging and I determined that the stator is dead! WSW is down till July 15th or longer as the website states and though I can find the kits none list big dog specifically! Thanks
HI Tim, thanks for responding I am definately interested! Can you tell me more about what you have? Is it the rotor also? What brand and amp? ThanksHave a bn vr and stator if u need. Purchased for my 07 as well.
I thought it had to be a 40 amp? Isn't the original 38?Here is one on Amazon
Compu-Fire 32 Amp Charging System for Harley Davidson 1981-99 Evo and Evo Style https://www.amazon.com/dp/B000GUWM5K/ref=cm_sw_r_other_apa_-ZIHxbPPRQSVE
Original is 32 ..just standard Harley evo.I thought it had to be a 40 amp? Isn't the original 38?
I knew it was Evo but thought it was a different amp set up! I appreciate the info! I will order it today and get back to riding! Thanks!Original is 32 ..just standard Harley evo.
Upgrade is to a 40..lot more $$
wanted to give an update and say thanks for the help! i put the compufire 40 amp 3 phase on my K9 and it is working perfect! very easy install! i think it is awesome that guys on here are so willing to help and even offer their spare parts to get a fellow biker back on the road!
Thanks for the update
Not a lick. Only difference with 3 phase is at idle it's like 14v.Since I installed the voltmeter on mine I can watch the volts as I ride and was wondering what the big advantage would be to go to the 3 phase? I have 13.3-13.5 at idle, and anytime I'm going down the road no matter what RPM's its running at 14.3-14.4 volts. Now I realize its not Amps, but does the 8 additional amps really make that much difference![]()
Extra amps are not needed on a big dog unless you got a stereo, heated grips and a bunch of other malarkey.
Unless the bosses have been grounded down before the rotor wouldn't fit square without it. Actually I don't think you could get it on, unless you took off the inner primary as well.Hey Guys.
So I just installed my 40 amp on my 09 K9. Pretty easy task but I did not have to grind any tabs nor did I use any spacers and other parts that came in the kit except the rotar and stator.
Did I install this wrong or is it possible that's its pretty much plug and play?
