Got a couple on order, should be here in a couple of days, let you know how it turns out...:bang:Their cheep and easy to change. wouldn't hurt a bit to try it.
Put everything back together.Got a couple on order, should be here in a couple of days, let you know how it turns out...:bang:
Good Job!!! :2thumbs:Put everything back together.
Air bleed=.050
intermediate=.033
main=.080
Back firing all but gone![]()
Just yanked mine after 3000 miles or so. Looks rich but let me know what all think? Not sure the jets I have. Left is front cylinder.Your rich at idle and mid circuit.
Go down to the 31 and then test it with the 76.
You may have to go back up to the 78 but your not at risk going to 76.
What jets are you running right now?Just yanked mine after 3000 miles or so. Looks rich but let me know what all think? Not sure the jets I have. Left is front cylinder.
Here some reading: http://www.bigdogbiker.com/threads/what-jets-do-you-run.14439/Will do. I will figure out the jets at that time too and let everyone know. Thanks for the help!
Main-78What jets are you running right now?
Ok. I've never drilled a carb before and I don't want to f**k it up so what is the best way to do this and what size drill bit should I use to get to a 50 on the air bleed?Do what Franco did with his spike air cleaner.
Go to an 80 and go to a 50 bleed.
You will have to drill and tap your bleed but its no biggie to do.
Just use grease on the drill and tap when you do it to keep debris out of the carb.
