http://www.bigdogbiker.com/attachments/image-jpg.25199/
Could someone explain how old these plugs look. Look at the left plug side electrode (L). Look at the green coating on it. Look how long it took to melt on the side electrode, then around the spark-flash, look how the green is knocked off by the arcing.
So without looking way down into the plug, the thousands of miles on these plugs... Looks like it to me... How could you come to the conclusion it's too lean if the threads are dry and clean, no piston ring damage, no piston score damage as if too lean.
Even with the right plug having debris melted onto the porcelain, a possible air leak on the one manifold, still causes the other to lean out too, show me why it needs a rejet.
Does the bike fall on its face we WOT the throttle? No.
Does it overheat while riding? No.
Does it smoke oil or use oil? No.
Does it start fast and idle smooth? Yes.
If all meet requirements, go head, waste more gas, more wallet, more carbon in the chamber, more decoking I'm too high of a compression, my bike keeps running; the carbon is glowing knowing it keeps firing off after key enters trouser pocket.
