Mittens,You and Bill will now be best friends. Old school on a chopper. Bill will be very happy.
:lol:????? don´t worry, you will get it itI dont get the joke?
look up some of Bad Dog Bills answers on ehc problemsI dont get the joke?
Thanks Kaptain - I'll take it apart and let you know if it's the wires. I did buy two LED's from you so I can try the other one that I haven't installed in the other bike yet. I'm back home now so hopefully I can get around to checking out that light soon I was on my 1600 mile trip and lost the light about halfway.Is it staying on low beam when you switch it or is it jumping back to High beam?
You will get taken care of by WSW.
Have you been having on going issues with your headlight?
If so then you may have to consider that there is something else going on in your electrical system.
Keep in mind WSW has about 300 of these lights out there now.
One of which has been in my 06 K9 for about 1500 miles now.
We had a couple of issues earlier on with a low wattage situation where the EHC wanted to keep jumping back up to high beam, we have since gone to a slightly higher wattage to resolve those issues, but beyond that nothing.
If the low beam is just gone let me know via email, wsworx@gmail.com, and I will get another light out to you with a return label and pouch so you can send that one back to us for review.
Just to clear this. I took the headlight apart and appears that the socket was a bit worn and H4 plug seemed to have moved just a little bit. LED Light works just fine. I replaced ceramic socket with another one I had laying around that was a very tight fit so I should be all set.Is it staying on low beam when you switch it or is it jumping back to High beam?
I think I better add a zip tie to the light and put that in the instructions.When I installed mine, I used a zip tie, to secure the harness and the plug together, so they cant back out or vibrate loose.
Well that's a hell of a good idea! You brought your thinking shoes that day.When I installed mine, I used a zip tie, to secure the harness and the plug together, so they cant back out or vibrate loose.
I wish I did that now wouldn't have had to pull it apart 2x, at least by the 3x ill have a better fix! hahaYep, just did not want to have to go back in once I got the light in. But i also wanted it removable IF it needed to be. zip tie, between 2 of the wires, on both the harness and the plug keeps it On the plugs, and pull tight. no worries it will back out.. and a simple snip, and its free to remove.
Good one Mittens! :2thumbs:When I installed mine, I used a zip tie, to secure the harness and the plug together, so they cant back out or vibrate loose.
