Yes it's left hand thread, so clockwise will loosen. If you heat it up, use a heat gun, not a torch. A good air impact will get it loose. Make sure your air compressor is up to 120psi.Wondering if anyone can help. Having trouble removing the clutch hub nut...2003 chopper.....Ive tried an impact didt work...heated it up...nothing...im assuming its reverse thread can anyone verify? thanks
Screw driver? Is the belt off, if not have someone hold the rear brake or borrow one of those thing a ma jiggers that hold it in place (can't think of the name for it).I cant get it. I heated it, used a breaker bar,,,cant get it. what a PITA. Using a huge screwdriver to hold the clutch basket from spinning at the same time is tough. Im gonna try again tomorrow Im beat for tonight lol
Yours being a Rivera Primo clutch, you will have a very hard time holding the center carrier in place while trying to loosen the nut. Your best bet is to use an air impact or even a heavy duty electric if you don't have air available. If your using a screwdriver to hold it, you will break something.I cant get it. I heated it, used a breaker bar,,,cant get it. what a PITA. Using a huge screwdriver to hold the clutch basket from spinning at the same time is tough. Im gonna try again tomorrow Im beat for tonight lol
Ive got a milwaukee HD electric impact. Hasnt worked so far. Im going to try again today. I bought a 24" breaker bar and a pry bar that I think will lock the center carrier. Ill try the impact a few more times but if I cant get it ill go for the breaker bar. Wish me luck!Yours being a Rivera Primo clutch, you will have a very hard time holding the center carrier in place while trying to loosen the nut. Your best bet is to use an air impact or even a heavy duty electric if you don't have air available. If your using a screwdriver to hold it, you will break something.
It's actuall the center carrier Im holding with the screwdriver, not the entire drive. but thanks for the tip!Screw driver? Is the belt off, if not have someone hold the rear brake or borrow one of those thing a ma jiggers that hold it in place (can't think of the name for it).
