ronson1977
Nice
Thanks bro, I will bookmark that page.Ronson, If you need someone to look at the bike try Carter Fabrication I belive he is in your neck of the woods. They have serviced my bike since new for the original owner. Once I got the bike I had a question and gave George a call and he was very helpful and told me to call with any questions I had, seems like good people. The bike has not missed a beat in the year I have had it. I wish he was a little closer to me than the 100 miles he is.
Carter's Fabrication & Design Co.
46 River Street
Dedham, Massachusetts 02026 phone 781 326-6166
Home Page
LOL nice dude. Thanks:lol:HELP I think I broke my dog!
It just hit me! Dude you know how many times I thought that in the last six years!!!! LOL!!!!! Your doing ok!!!!:2thumbs:
Unless you have ported head, bigger valves, 0 deck on you cylinder, heads milled 0.030 and a big ass cam you can say the 33 is way to big for your dog. I have all of the above with 3-D sinful FSD pipes and more and I run a 32 and 78 with adjustable ignition thunder heart set at "E" and my dog runs great. Occasional decel pop depending if I want to wake up the neighborhood or be nice :lol:Thanks I swear it's impossible to get these carbs dialed in. The mixture screw travels out too far so I put a bigger intermediate (33) and it back fires like crazy on decel. Seems like the decel popping is impossible to get rid of... and the screw still seems to come out too far. I'm wondering if I don't need a 34 but I would think bigger would only get me more popping.
Carlos[/QUOTE
All I have is the XXX carb, troublemanker exhaust and now the 585 cam. So it seems I will go back down on the intermediate. I have to wonder though, why is it that when I back the mix screw out to get the top end stumble for finding the mid point between top and bottom stumble, it's practically all the way out and still no significant stumble. I thought that meant lean?
I'm not sure what you're talking about with the rubber barb plugs.you might check your carb and manifold and make sure all the barbs have a rubber plug on them...if mine starts decell popping badly it means ive lost one...just a thought...
Right on !it sounds like your pushrods lost there adjustment....maybe the lock nuts backed off....re-adjust pushrods and give it a go
The screw you are adjusting is for the idle metering circuit only...plays no role once you give it throttle.Unless you have ported head, bigger valves, 0 deck on you cylinder, heads milled 0.030 and a big ass cam you can say the 33 is way to big for your dog. I have all of the above with 3-D sinful FSD pipes and more and I run a 32 and 78 with adjustable ignition thunder heart set at "E" and my dog runs great. Occasional decel pop depending if I want to wake up the neighborhood or be nice :lol:
Carlos[/QUOTE
Oh okay. See I thought it played a roll with the intermediate. Didn't realize it was for idol ONLY. So there is no running adjustment then, it's all in the jets.The screw you are adjusting is for the idle metering circuit only...plays no role once you give it throttle.
I'm gonna take a look, do you have any pics of the plugs?the manifold and carb vaccume ports or connections...mine has 3. one has a rubber hose that ties into the heads...the other 2 arent used and have the rubber bullet looking blockoff boots on them...if mine starts backfiring or decell popping more than normal [and mine dont do it bad at all] i can bet ive blown one off and need to replace it...just a thought.
Correct :up:Oh okay. See I thought it played a roll with the intermediate. Didn't realize it was for idol ONLY. So there is no running adjustment then, it's all in the jets.
