rasdes
Hello to all....
Lots of great info and help on this forum..thanks to all that have ever replied to anyone!!
My bike was jumping forward when I shift from N to 1st gear. Decided to adjust the clutch. Read just about every thread on clutch adjusting, followed all instructions to the tee. The only way I can stop the jumping when going from N to 1st is to continue turning the allen screw in well after initial resistance is met, this is approximately 1 to 2 complete turns after taking all resistance out. After that I then take all slack out of the cable. N is easy to find, no jumping forward. Will this hurt the clutch, is this OK...normal, what could be the cause to turn it in that far? Most say tighten the center screw with your finger, tighten the lock nut; that method causes the bike to jump even worst, the more I screw the center in, the smoother the shift from N to 1st....any ideas is much appreciated..
