allenmp
chop03
I have a 2003 bdm chopper with 3" forward control extensions and when I am ridind and shifting through the gears the lever sticks in which ever gear I am going in a local shop just got done rejetting and servicing my bike and noticed it sticking and said I can take the assembly apart grease it up good and should be good it was only doing it once in a while this winter when I would ride when it was pretty cold now its starting to warm up here it does it all the time so I took apart the assembly and the 3/8" bolt that goes all the way through the assembly to the peg dont come out unless i.wasnt hitting it hard enough so I greased it up the best I could and put it back together and still sticking
My question is does the long bolt come out or are the bearings pressed on it and if so how do I change this piece out and any suggestions on where I might get the parts I can post pics soon if needed
Thanks mike
Thanks mike
