How To Install your Dyna Beads
Dyna Beads
Most of us get them from Low Down Chop Shop as described in THIS THREAD.
Many of us have got them and many are probably on the fence. But if you got them, here's how you put them in.
Grab your supplies
Cut the top off the applicator for easier pouring
Grab your bag of beads
Cut open the corner of the baggy to dispense into applicator bottle.
Pour into the bottle
Simply put that stuff aside and time to direct attention to the bike itself.
So I jacked up the sporty like so...
Remove your valve stem cap
Get your valve stem tool
Spin out the valve stem slowly allowing the air to leak. At this point you can either let it all leak out or pull it out carefully. Be sure not to go to fast and put your hand over it, while keeping pressure down on the tool and stem. You are trying to keep the valve from flying accross the garage.
Out comes the valve
Set this aside
Hook up the tube to the valve stem
Start to pour in the beads slowly. If they start to back up and won't flow into the rim like this read the next direction. If not skip over the next part for difficult bikes.
In some cases your beads may not flow in easily. My Big Dog was no problem the Harley was so I got to thinking outside the box sense I didn't have an engraver to aid me.
Loosen the valve stem nut holding it to the rim.
Attach the tube
Fill the tube and it will back up like before. But push the valve stem in and out shaking in the beads. You can fill the entire tube and then shake in. This worked great for both front and rear tires.​
Now once you have all your beads in, remove the tube. If you had to do the difficulty step, tighten the nut.
Re-insert your valve in the stem
Fill it with the proper air level
Check the pressure to make sure its right.
Now replace your valve stem cap
Repeat for the rear or other tire
Out with the valve
Fill and re-assemble and put the valve stem back on. Ride and enjoy a smooth ride
bdmridgeback
Low Down Chop Shop
Hey, Thanks Chris! That might help a few guys out when in question about do them.
Nothing like a Great How-To by Gas Man!!!! :2thumbs:
seatmaker
Do they just bounce around loosely till ya get up to speed or do they settle in place after a few miles?
bdmridgeback
Low Down Chop Shop
They settle in to where they need to be starting at about 5 miles per hour. They really don't bounce around in the tire. They get a static electrical charge and roll freely in the bottom of the tire until you get to about 5-15 MPH.
BubbleHead
Big Dog Biker test account
Hey Gas, I have 8000 miles on my tires. Should I get these now or just wait till I get new tires? Are they for balancing new tires or will they help my exsisting tires last longer and ride better than they do now which isn't bad whatsoever at this point. Thanks, BBD
I think the actual website says they lengthen the tire's life. I got 6k on mine and they look great and figure... why not make the next 6k ride smoother and maybe last longer. Dude... you have no idea how much better it looks without the weights!!! Trust me... order some! Jake's site is super easy to use!
Jake... no problems man... feel free to link or jack what you want... as long as I get some sweet credit for it... store credit would be a plus! :lol: J/K
choppersforlife
CHOPPERSFORLIFE
HOW MUCH WEIGHT ?
First, thanks "GASMAN" For another awsome "HOW TO":2thumbs:
How much weight should I use in the Front and Rear of my Dog ?
04 Ridgeback 250mm rear
Should I simply just remove the existing weights and weigh them to be exact ?
HELLLLPPPPPPP !:bang:
Thanks in advance
BubbleHead
Chris, I don't have any weights on my wheels at all . Do you think this will affect my tire balance since no weights were needed on my wheels? I'm all for getting longer tire life and a super smooth ride.
BBD
chops4life... just go to Jake's site. Buy the kit for the 250mm rear tire. Its only $10.50!!!! and it will only take ya 15-20mins to put in.
bbd... I haven't rode mine yet, obviously look at my phoenix thread. But everybody that has, loves loves loves them... I would do it anyway... like I showed above... its so cheap!
lee
agreed - I never had any weights on my wheels either and it seemed fine but it does seem smoother with the beads and I believe my highspeed wobble may have gone - and as Gas says for the price you can't go wrong
Vegas
Gas...love you like the brother in law I never had. Some of these insult the intelligence around here. :hi:
BubbleHead
Gas, I ordered them today. I figure if you and everyone else believes in them then how can I go wrong?
Thanks for the info on these and the great how-to pictures as always.
BBD
Milkbone
For those that don't have weights already...should your install dyna beads or not? YES, for two reasons.
1. There's no guarantee that whomever mounted the tires to the wheels even checked them for balance. Some believe that if the little tire "dot" is aligned with the valve all is good, not necessarily correct.
2. Unless you're experienced and balanced your own, there's no guarantee your tire/wheel balance is accurate whether it was accomplished by the factory or aftermarket business.
Case in point -- One of my bikes is new with factory weights. Pulled the weights off and installed the beads. Guess what? My mirrors are clearer and have less vibration.
Gas Man provided some great install advice. One more I found worth while is to lift the bike off the ground on a stand so the wheels spin freely. If the filler tube gets backed up because you were trying to hurry the job, just spin the wheel 180 degrees so the beads fall back in the applicator bottle. Basically it'll take about 20-30 mins to do two tires/wheels.
Later,
bdmridgeback
Low Down Chop Shop
Also note that when you remove your weights that are on your wheels, just because your bike has 2.5 oz. of lead doesn't mean that you have to replace it with that much Dyna Beads. My bike had 2.5 oz. on the front and I put 1 oz. in and it was perfect.
The application amount is all based on three things:
Wheel Diameter
Tire Width
Tire Overall Diameter
These three things put together will deturmine how many ounces of Beads are installed. Also if a tire is a bit more out that it should be, it may require one extra ounce to smooth it out perfect.
I stock 1 oz thru 5 oz bags and kits to cover all BDM bikes, custom bikes, Harley, Metric, and sport bikes. If you need a custom application or for a auto, contact me through my website or a PM here.
Thanks Gas for the How-To, I owe you one!!!:2thumbs:
Milk...good call on getting the wheels off the ground which I did do as shown in my pics of the bike on the sears jack.
Jake... no problems bud...
bdmridgeback
Low Down Chop Shop
:hi: Will this work on a vette? Getting my vette off ground at home not an option. Woodysan:flag:
I have sold kits to guys with sports cars and street rods. I know for a fact that a couple guys were putting them in Corvettes. You just have to roll it till the stem is at 7-8 o'clock or 4-5 o'clock position for best results getting them in.
