bryant1609
Just completed installing my 4" Karata Belt Drive today. Picked it up from Jim on Saturday and started work as soon as possible. I used the guide written by Gas Man and the Karata instructions and some tip from Jim. This is not an install thread but I just want to list some things that will make your install faster than mind. Frist and most important thing is to have all the right tools, and don't assume you do. The is a list of things to get if you don't have.
1. STRONG IMPACT Wrench, NOT THE CHEAP ONE FROM SEARS made by Craftsman’s (Can't do job without this
2. A "1 5/16" Socket for the engine bolt (most 1/2 set don't have this size check before getting started)
3. A 30mm Socket for the transmission, YES I SAID 30mm, it fix a lot better than the standard size and appears to be Metric not a standard bolt.
4. A set of Snap on Piles (pain in the neck to find too)
5. Rubber Hammer (If you don't have one, you will need it to get the belt on)
6. A 12" sprocket extension came in very handle. (Reach starter bolt)
7. BEER
Note: I didn't undo the transmission as Gas Man did during the installation because Jim from Karata said to try the Plate first and it fit prefect.
I haven't tried my belt yet because I'm waiting for my carburetor from XXX to come in so I have none at this point to try it out. But my wife even agreed that the bike looked BAD A$$ now.
7. BEER
