I HAVE ONE, BUT HAD IT INSTALLED BY DEALER.....LOVE IT...WHAT A DIFFERANCE
Replace cable ramps and clutch pack, so it would be both sides to answer your question. Do a search I showed pics of the soft pull kit on another thread (clutch nut or cable) bottom of first page. Sorry i don't know how to attach link.Has anybody installed one of these themselves and how hard was it to install.Do you have to remove primary and whole clutch system or is it done on the cable side?
I have it in mine and I don't have no issue with the 9 plate clutch but if you are a "hotrodder" then it may be a different story.Thanks i found it,so if you and lee didnt use the clutch pack you dont need to take primary apart right just cable ball ramp side ? are the stock 12 plates better than the kit 9 just dont want to take clucth apart for no reason if not needed to.
I didn't put the 9 plate clutch in however I think its just on the edge with the stock clutch. The lever is definitley easier but to adjust the clutch, I found it very touchy to adjust, meaning it doesn't go into neutral when your at a stop every time but better than an out of adjusted clutch. If that makes sense.Thanks i found it,so if you and lee didnt use the clutch pack you dont need to take primary apart right just cable ball ramp side ? are the stock 12 plates better than the kit 9 just dont want to take clucth apart for no reason if not needed to.
You can purchase just the easy pull ball and ramp. It will work with your old style clutch pack and you are better off having the old style over the new as long as your pack is still good and in spec. I make a performance spring that will take place of your stock one if you think you will have slipping issues. It does add a little extra pull at the lever but is worth it if you are a hot rod guy. Gives you a good 30% gain over the stock spring. The newer 9 plate does have a tendency to slip more than your older style will.Why they can't just sell the ball and ramp assembly I don't know.
Sounds like just some minute adjustment.your right neutal is a pain till it warms up.
be shure to grease the long clutch rod inside the imput shaft!
Grease NOT anti seize, along the whole length of it and at the end that rides against the throwout bearing. If you don't use grease, you will end up having squealing noises every time you pull your clutch lever in.Sounds like just some minute adjustment.
Also the clutch rod should be lubed with anti-seize and not grease.
Ha ha, we use to have one of the engineers on here that got laid off from the factory that told everyone to use anti-seize!!!Grease NOT anti seize
So you were joking about the Anti Seize??Ha ha, we use to have one of the engineers on here that got laid off from the factory that told everyone to use anti-seize!!!
I wish I was told that when I bought mine.You can purchase just the easy pull ball and ramp.
No, will have to look back at some old posts but one of the BDM Field engineers that got laid off use to offer a lot of advice on here and he always told everyone to use anti-seize on the clutch rod not grease.So you were joking about the Anti Seize??
:2thumbs:
Hum I think I remember that story from when I was out in Kansas. This may be the same guy that told everyone at the factory to use only one drop of Red locktite on the Compensator and Clutch hub nut, and the guy that started making up his own clutch adjustment procedures and us dealers had to correct them all.No, will have to look back at some old posts but one of the BDM Field engineers that got laid off use to offer a lot of advice on here and he always told everyone to use anti-seize on the clutch rod not grease.
Just goes to show you that everyone has their own thoughts and we have to make the final determination ourselves. I've been using anti-seize on mine for the last couple years and have put a few miles on it without any issues.
:2thumbs:
Could be but you may remember that what was it... In 05 & 06 they were replacing a lot of clutch rods due to them being machined wrong or maybe to big. Lots of scoring on them so maybe the reason for the anti-seize.Hum I think I remember that story from when I was out in Kansas. This may be the same guy that told everyone at the factory to use only one drop of Red locktite on the Compensator and Clutch hub nut, and the guy that started making up his own clutch adjustment procedures and us dealers had to correct them all.
Just sayin, there may be a reason he was laid off
Anti Seize is developed for use as an Anti seizing compound, just as it's name states. It does not give a lot of lubricating properties. It's purpose is to keep fasteners from forming corrosion between the two metals.
Such as using it on your front and rear axles, not for lubrication of the bearings (they are sealed) but to keep the axles from bonding to the bearing inner races and bearing spacer. You want a lubrication type substance on your clutch pushrod due to the fact that your mainshaft is turning and the pushrod is fixed inside this. Grease works best for this application.
Just my 2 cents.... I'm not a bigdog ex engineer so what do I know![]()
Could you or someone please tell me where I can purchase just the ball and ramp set up for the easy pull. I've called two dealerships in my area and they both have told me that I have to purchase it as a set because thats how it's listed.You can purchase just the easy pull ball and ramp. It will work with your old style clutch pack and you are better off having the old style over the new as long as your pack is still good and in spec. I make a performance spring that will take place of your stock one if you think you will have slipping issues. It does add a little extra pull at the lever but is worth it if you are a hot rod guy. Gives you a good 30% gain over the stock spring. The newer 9 plate does have a tendency to slip more than your older style will.
