N8KAM
Hay Slowrower any more info on the low oil psi ??? Mine dose the same thing. I notice it more if i shut it off and restart it shortly there after... comes right up with some throttleClosing in on 1,000 miles on my 07 Mastiff and so far no big problems, I did notice as the miles rack up it runs better and better - go figure.
I have a question .. I installed a Pressure gauge and still have the oil pressure switch as well. When I start it up pressure reads about 30psi and as it warms or at idle about 15-20psi. When I run it hard for 10 or 15 miles say at 2500-3000 rpms when I come to a stop the pressure reads 0 psi, if I give it some gas it goes to maybe 15psi -- the pressure switch is working fine. Is this normal??? my HD would drop to 7psi at low idle. I am now concerned there may be something wrong with the oil pump that causes it to lose pressure when hot. Thanks Guys!! if your ever in the Central Florida area lets have a beer!
Been an excellent bike. Two starters, neck bearings, handle bar bushings,couple recalls, needs battery covers. My speedo just broke last ride and I have one fork seal that is seeping. Very happy with my bike, it's not going anywhere. Time for a service and a fresh coat of wax.
