Open Primary
WB Cycles
yes, thats the one. I like the drag race style.
Does it come in chrome? Can you PM me a price polished and in chrome?
Here you go, check out Ultima's website for additional information on the actual drive:
http://www.ultimaproducts.com/beltdrive.htm
BILLET
Drag Race Style Belt Drive
Assembly, Polished
58-800 $1,016.25
BILLET
Assembly, Machine Finish only
58-801 $988.95
CAST
Assembly, Polished
58-700 $883.95
CAST
Assembly, Machined Finish only
58-730 $757.95​
As of this afternoon I'm told that all are in stock.
Rick
So besides the cool factor what are the advantages of the open primary? I have the stock oil leaking through teh starter primary. Have given the dealer one more chance to fix the oil leak (bike is actually there now.) If is leaks again I am considering an open primary, but would like to know for the $1000 is there any other advantages besides more noise, and no oil?
seatmaker
Didn't know I could do that. Always liked the look. Believe you can have a design put into the belt also, but again Gas beat me to it again. Don't want to look like a copy cat. Gas, let me know what you're not doing and I'll put it on mine.:loony: Rainman, no more messing with primary oil? Why's that? Educate me fellows.
CCRainman
Scott, the belt is dry. There is no fluid involved as where your primary is swimming in gear oil and is chain driven. The belt is dry and opened and no oil to mess with. You save money on fluid, clutch can be serviced without the fuss of opening the primary up and you loose some weight. How can you go wrong with all these pros. Besides looking good
seatmaker
Gotcha, I was thinking the belt was already in there. Got some learning to do eh? Is this something that I could do myself or should I take it over to Gas's house?:rolleyes:
TCALZ06
wont fit your 07 BD with the dssc set-up. only the RMD, karata or baker fit our 05 and up BD's. IMO
Thanks Sul, One of the shops I called for installation thought it wouldn't fit
I want one that has the bearing support but not a solid plate so that from the side it looks like an open belt drive
Like Rain says, no more leaking starters and shit. But it definately isn't a $1000. Almost 3 times that!!!
Hey you can copy... I'll ever help. Just don't copy everything, please.
where can you find an rmd?
http://www.rmdbillet.com/
And you can order it from Pink Chopper.
take it over to Gas's house Scott :up:
Bring it over... anybody can... we'll get it done.
TCALZ06
How many hours should it take for a shop to put one on?
I was just told 6-7 hrs at $65/hr
Gas,
Is the install straight forward, good instructions ect on the RMD?
Was their any certain reason besides looks that made you pick RMD?
Thanks
CCRainman
Gas,
Thanks
TCal, don't let those stealers do it. Save the money for more bling. Like Blitz said, it's an easy install about 2-3 hours tops. Just make sure you have all the proper tools. If you have the correct tools, it'll be a sinch. Make sure you have a strong impact gun and the right sockets. Oh yeah Loc Tite.
Gas,
Thanks
I have yet to do my install, it will be a while longer for sure. I still need to get the parts, and do the complete rebuild of the chop first. I'm not sure about the instructions... will see when I get it.
I got the RMD cause they make it specifically for the RSD big dogs. Plus it comes chrome vs polished. And it comes with a Banditt clutch.
Fibersnake
Banjo Playing PsychoBilly
It may have been mentioned on here already and if so Bad on me,
One of the things to keep in mind with an open belt primary is that the belt and pulleys are exposed to the elements. If you get a rock or some other item that gets thrown up from the road and between the belt and pulley, it can and has happened many times of having the teeth of the pulley get damaged as well as tearing up the belt.
Also you need to be careful with the leg around the pulley (they hurt when you get the pant leg snagged-don't ask how I know).
Many advantages but there is some disadvantages also to be fully aware of. One thing for sure, a nice open primary is always an attention getter, especially if you have a custom painted belt!!!
ronin1r1
Can anyone out there tell me if I can use the Ultima 58 - 730 Open primary on my 05 Mastiff? Mine is leaking oil through the starter Drive and I would like to go open belt anyways.
Nope ...only baker or karata will bolt up. The inner primary back plate is not the same
