Hi Ray,
Did you use any loctite on the pinch bolts or axle?
Just curious
Thanks
Tom
You probably could if you used some kind of puller. But with a bearing press I doubt you could fit the big wheel in so just a lot easier to pull the hubs. And makes polishing easier while you have it apart.Great job! But why do you need to take the hubs apart to get to the bearings? Can't you just pull the seals and then the bearings?
Trying to learn...
Fred
Well you did a lot better than me cause I couldn't do the rear wheel. Not enough dish in the rim, even the shop using a tire machine has a hard time getting the tire on these wide rims.Great write up Ray. I just did this about a month ago, front and back on the Ridgeback. You make it look easy but it's quite a work out to get those beads back around the rim. At least it was for me. Like you I used brute stregth to put the tires on and tried not to use the tire tools unless I had to in fear of scratching the wheel due to a slip.
One point on the bearings, I work with industrial machines for a comapny called Ingersoll Rand. We use bearing suppliers like Kaman Bearing, Motion Industries and others. They can take the numbers off just about any bearing and they either have it, can get it or can cross reference it to another brand. They also have a data base with dimensions etc to be sure they match up. So if the dealer doesn't have them or wants alot of $$ for them it's an option. :up:
:2thumbs:
It's best if you just take them down to your local auto shop that has a press. They will seat with authority and a few hundred lbs of pressure!I have a quick question----how far do you press in the new bearings? Is there a stop in the hub? I'm getting ready to change the front ones tomorrow, and just trying to get all my info together before hand. Thanks:up:
