Nomad2day
Longhair Redneck Geek
Last week one day while cruising at a steady rpm 2-3K, the bike lurched like the primary chain bind-ed or jumped or the rear drive belt jumped a tooth. Thought maybe the clutch slipped for a second and then grabbed too. I did put some pipes on and adjusted the clutch, grease the ramp and rod in case it was the clutch adjustment. The clutch starts to grab pretty close just after you start to let the handle out. I had a wrench on the primary nut and checked the clutch basket nut then too, to insure it was tight.
Anyway, yesterday I took it out and it did the same thing again a few times. Feels like if you were peddling a bike the chain jumps a tooth or two.
The final drive belt does need to be replaced due to a couple of gashes on the top side but none of the teeth are damaged. I tighten the belt up some anyway. I opened the primary inspection cover and adjusted the chain tension up some. Maybe a little loose but seemed pretty good. Took it back out and it jumped some more.
What do you think I need to revisit and check. Does not do it under acceleration but while under a steady RPM, 3 k anyway.
I am going to open the primary cover again and see if the primary drive nut came loose and the compensator is loose.
Any Other suggestions?
Thanks in advance for any direction,
Neil
Neil
