Thanks to everyone so far on words of wisdom and what to check. Learned a few thing about having a eye for detail and looking at everything.
I think the problem is in the transmission and I will tell you why. I had another transmission issue in July just before I went on vacation thinking it was the throw out bearing for the most part. I have a thread on here from that.
http://www.bigdogbiker.com/forums/drive-train/5820-roaring-noise-when-clutch-pulled-07-bulldog.html
Here is one post from it....
BBChopper,
I am believing the it is in the transmission. I do not know how the internals work in one so someone can point me in the right direction, here is my take of it.
When I had the clutch pack out, I reached down and grabbed the clutch Basket nut and rotated the shaft "Mainshaft?" by hand and had a roar noise here like a bearing was scarred. Was not smooth by any means anyway. Anyway may question is the mainshaft being supported by the 5th gear bearing? What is the bearing called that supports the shaft coming out of the transmission case? Appears it is roaring . When I drained the transmission, it was contaminated with moister and just a brown liquid muck.
perhaps someone can point me in the right direction here and the proper way to replace this bearing.
Thanks,
Neil
Anyway, when I drained the transmission then it had a lot of metal contamination. Last night when I pulled the shim out where bdmridgeback told me to look I put it in my wallet. Today at work I looked at it and it is embedded with metal all around the face of it where it was against the bearing in the transmission side. The above post was talking about the roaring and rough feel when the shaft was rotated. Something is ate up in the transmission allowing the clearance to be reduced were the hub is against this shim. I can feel play in the mainshaft if I move it around.
Here is a couple of pics of the metal embedded in the shim.
For the metal on the magnet. The chain had been rubbing on one of the inner primary mounting bolts by the primary gear. You can see where the side of the chain had rubbed on the face of the Bolt. I guess I need to pull the transmission all the way out and open the top cover and look and see what it looks like inside and call Big Dog and see if they want me to drop it off at one of there shops to ship it to them or call Baker. Makes it easier seeing how I have everything disassembled.
Perhaps between the clutch basket nut coming loose a whike back something got out of tolerance and wore down.
Anyway, just another evening in the garage....
Neil
