So I’ve got past that, but now I have encountered another problem. After assembling and testing deflection of the clutch, one side is deflecting more than the other. I have taken it apart and tried without the shims under springs and same thing, I’ve examined all the hard parts and see no debris in there. So what could be causing this? Is it normal to expect this with the slight wear I had in my clutch basket, or could it be bc of me using a file and trying to smooth out the tops of the teeth where it has ridges…maybe I didn’t file it down perfectly evenly or something? I would think that removing material from the top of every tooth, would make them move MORE freely if anything, since I’m giving more room for the frictions? Or could it just be bc I didn’t file into the and is just getting hung up there? Best case scenario I’m hoping is maybe I didn’t press the actuator rod button all the way into the throw out bearing in the pressure plate causing it to tilt the pressure plate when engaging clutch and pressure is applied to the button…. Who knows. I am over it, calling it a night and if can’t figure it out tomorrow I’m setting this mother fucker on fire. This is so fuckn frustrating man…I hate this bike.
