I have lights on the EHC when I hit the run button.I would say this..
check the ehc lights
Turn on the key
check the lights on the ehc
while looking at the ehc and the ignition
hit the run button
you should see the light on the EHC come on, that sends power to the ignition, you should also see some power light on the ignition come on when this happens.
When it cranks you should see the lights blink on the ignition
Also when the power comes on the ignition it should send power to the coil.
Yes with the spark and I'm currently running through the chart we got from Sul.got spark at the plug?
check the flow chart.
Ask me no questions and I'll tell you no lies! This bike is Satan I tell you!How in the hell do you have spark with no power at the ignition... coin the title of the thread "WTF"
not woodbutcher I hope![]()
i want to clear things up a little bit here. no matter how much ya'll touch wood, rub wood, or anything else to do with wood, you get close to me and i'll cut ya'!!!!!!!!!!!!!!!!!! :roll: :roll: :roll: :roll: :roll:
I'd like to try just the box itself before following through to doing it all. I might be able to get the all of the wiring connected into a different TH box.I have my thunderheart unit I could get ya but its not the nose cone unit that you have...
