Wolf
Scott
Anyone having any issue with Wolf neck bearings going bad. When I turn side to side there is a catch (moderate resistance) from midline to side. I'm thinking bearings have gone bad or atleast one or more have developed a flat spot. Outside of taking to dealer (4 hours away) does anyone know a reputable bike mechanic around sw wisconsin or northern iowa and illinois who can fix?
Without going out and buying a quality lift I could probably fix myself but at this point it is more than I can do myself. Big dog has the appropriate bearing in stock. I figured since front end will be off I might just as well as service forks and fluids. On the other end both tires need replacement as I have a squeak in the rear right side of bike. Thinking may be rattle pin or warped rotor. New brake pads last fall front and back. Thought this would solve problem but has only made sound in rear worse??? Any suggestions? Thanks Scott
cvegmond
I don't own a Wolf, but I'm a very BDM mechanic. My K-9 has 20,000 miles without any head bearing issues. Your Wolf should have the front-end removed and replacing the fork bushings is a good idea.
This is an easy job for even a non-mechanic. You'll need only one special tool for your repair...a 41 mm seal hammer. A foot operated motorcycle lift is less than $200 and you should own one if you also own a BDM.
I also happen to have a head race press tool, but I've done this job many times with a rubber mallet and big screw driver.
Work slowly and thoughtfully.
You can do it
