what's the avreage mileage from the front and rear brake pads?
BubbleHead
Big Dog Biker test account
I have 8900 miles on my 07 and they still look real good. What's the most anyone has gotten from there original pads? Just curious.
:hi: thing is slow, he's always going and never stopping so he shouldn't ever have to replace his pads. :roll: :roll: :2thumbs: :2thumbs:
dogvet
Banned
If you use both brakes alot, you might get 15,000 miles out of them, it just depends on how and where you ride. IF most of your time is highway, the brakes last longer. street riding uses pads up quicker.
BubbleHead
Thanks DV, you da man :2thumbs:
BubbleHead
Hey DV, is there a better brake pad that lasts longer than the factory ones available out there?
dogvet
Banned
Good question! I'll have to do some research on that one. I know the the sintered metal pads are the ones that BDM has been using for years. I don't know if organic compound pads are any better.
slowrower and woodbutcher are funny characters! :D
I can't remember changing out my front pads but did soon after getting the bike so I could get rid of that rubbing sound. You guys hear your pads making that soft grinding sound as you slow to a stop light.
I changed mine out to the Z-Plus from LRB probably a couple years ago and wanna say it was at about my 22,000 mile point when I changed the front tire after returning from my summer run over to Memphis and Little Sturgis in Kentucky.
I did my rear pads after moving up here last year again to the Z-Plus that are very quiet and are long lasting and that was at about the 35,000 mile point. But again hard remembering mileage now a days!
But as mentioned I have about 50,000 miles on my Chopper now and my stock pads lasted a long time and my Z-Plus are doing great and will probably last longer. Most of my miles are all Freeway so not much stop and go. I do use both my front and rear brakes.
Lyndall Racing Brakes - The worlds best Brake Pads & Composite Rotors --- Home ---
I have changed out the pins in the floating rotors several times though!
Later,
Ray
I bet Raywood can answer this one .. seeing how he wins the cast iron butt award!!
BubbleHead
Hey Ray, that mileage you guessed at ( 22,000 for the front tire change) was that your first front tire change? Also was the rear brake pad change at 35,000 the first change out for the original factory pads as well?
Yes to both. :cheers:
emcclary
I was wondering about that noise from my front wheem I though the brake pad had something caught in it but after putting on my chromed wheel it was still there so ti has to be the pads.
KnotSo
Admin
Ray's brakes should last longer as he is not bar hopping, he is riding hard and only using the brakes to get fuel...:cheers:
dogvet
Banned
Probably the drilled disc making the noise.
Fibersnake
Banjo Playing PsychoBilly
I also get the noise from the front when coming to a stop. I agree that is more than likely the drillings.
The brake pads as already said, will depend on your riding style and type. I just had mine checked and the rear had to be replaced at 15k, the front still have good life left on them. Tend to use both evenly for straight roads, but do use the rear a little more in the twisty roads back roads over where I live.
TCALZ06
Later,
Ray[/QUOTE]
Hi Ray,
What are these pins and what caused this? or what should you look for?
Thanks
Tom
Later,
Ray
Hi Ray,
Thanks
Tom[/QUOTE]
Tom, grab your rotors and try to rotate them. If you have excessive movement (documented in a previous thead here somewhere) then they need replaced. But they are the "button" pins that hold your rotor to your carrier.
Side to side travel is not a condition for replacement as I've been told just the forward/rearward movement. There is about 10 of them per disc.
They are cheap and I've replaced mine a couple times now.
:flag:
