I am Thor Member Jan 16, 2013 #1 I guess it's the valve covers each one has a hole guess its decompression one has a rubber deal in it other one doesn't do I need both if so where can I get one and what are they ??
mcgroom Well-Known Member Jan 16, 2013 #2 Sounds like your compression release's. Cover is meant to protect release. Pics may help to confirm
BadBrad 2005 Pitbull Jan 16, 2013 #3 I'm pretty sure that Amy/Strokers (214) 357-0707 can get you your compression release condom.
I am Thor Member Jan 17, 2013 #6 What is there to putting them in the one that is in doesn't act like it wants to come out
05 old dog Well-Known Member Jan 17, 2013 #7 they are very tight...just have to work them down over the CR and wire...the old one is gonna be tight....water seal and all.
RRRUFF Well-Known Member Jan 17, 2013 #8 Soak them in some hot water for a while then put some WD40 around the inside. This should help.
john sachs Well-Known Member Jan 17, 2013 #9 A little spray of WD40 will definatly do it. Just slide them down, over the release and wire. John
I am Thor Member Jan 19, 2013 #11 Well I got the old one out several pieces but out get new ones tomorrow
