Nomad2day
Longhair Redneck Geek
At what AFR do you create the most power at if this is a accurate question?
13-1, 12.7 or what realistically is the best.
In my case I have a 11-1 compression, 2.02/1.615 valves, Red Shift 656V2 cam, port and polished heads, R&B Racing 2-1 pipe and so on. Where should I try to have my AFR at? I am running a wide band system so I can put it where I need to be.
I am going to force the fuel here and observe the map after driving it some.
Thanks in advance as always...
Neil
Neil
