Warning lights on speedometer
nobbyjohn
The lights at the bottom of the speedo on an 04 ridgeback like the high beam & neutral light. Are they bulbs or is it a circuit board,can this be repaired or am i looking at whole replacement
1mndg
RIDE IT HARD!!!
They are LED bulbs on a circuit board. Would be touchy to replace the bulb if that's what the problem is. But should be able to do it.
nobbyjohn
About a month ago the high beam stoped working & now the neutral light is out just wondering what i'am dealing with before i spend 300-400 hundred for a new unit.
armad
neutral
Is the high beam in the headlight itself working? Or is it just the highbeam indicator that is not working?
I have the same exact issue on my 04 Ridgeback. The previous owner said that it was because a Wire Plus EHC was installed which I later found out was wrong. Let me know what you find because I would eventually like to fix mine as well.
francoblay1
The Spaniard
Sorry to hijack in here.. I have another question....
Why the speedo stops working every now & then? Once I stop the bike, and start it again it works fine again!!! just curiosity. It doesnt really bother me as I ride by ear.
Thanks guys :cheers:
Thors
I would check the connectors/connections for loose or corroded contacts. Same issue on my 05 Pit turned out to be just that. A little cleanup and reseating and the problem hasn't returned...yet. :)
bruce
what Thors said, it was common to get corrosion bluid up and also for the wires to break ( just re-solder )
You talking about tach not working all the time? Let the speedo sweep completely before hitting run, gets me a couple times so I just turn off and start again.
yeahitsfast
Indicator lights
I have a 2000 Big Dog Wolf. I have the same issue. My indicator lights went out one at a time. I looked and the circuit board is installed surrounded by a rubber compound. I called around and was told that I would have to replace the tank cover that housed the indicator lights below the odometer. They found one at a cost of 135 plus shipping. I ordered it today. I will update here when it arrives and after I install it.
