turn signal
allenmp
chop03
I have a.2003 bigdog chopper still had stock turn signals on it well the vibration has finally taken its toll and the two on the right side and they broke so I found some I like with the Arlen ness PN-12772 when I ordered them from cruiser costuming they could not ensure fitment but was pretty sure they would now the problem is that the stud I have on my bike is 5/16 coarse thread and the ones on the new lights are 5/16 fine thread so I called them and they said the stud don't come out of the lights so I think I can put a for clamp on to make the front two work but my question is
Are these 41mm forks on these I think they are but not sure and if so does anyone have a suggestion where to get the clamps
And another question is any creative ideas for making these work on the back without having to drill my struts I thought about maybe swingarm mount but don't know how it would last there I have gotten ahold of bdmpp on the forks but they don't seen to know much or give a shit about an old dog any suggestions would be awesome
Thanks Mike
BigDogNZ
sheeesh Mike, did y'all draw breath anywhere there??
calipers will give you the exact dimension of your forks I suspect.
being creative, could you make up a male/female adapter for them? Not sure if tapping 5/16 coarse to 5/6 fine would work but what if you
- took a 5/16 coarse bolt that has an unthreaded neck section below the head,
- cut the head off,
- thread the neck wiht a die to 5/16 fine,
- dimension the length of each end appropriately,
- screw the coarse thread end in to the existing threaded receiver,
- wind a 5/16 fine thread long nut or tapped tube onto the protruding end you threaded with enough unused length in it to wind the turn signal bolt into.
- finish it all off cosmetically how you want
Yes? Maybe?
