Dogbone
IF LIFE SUCKS, GO RIDE
All started when i had the lower front cylinder oil leak on the gasket. posted here some where. Took out motor-removed both heads, jugs, replaced gaskets, replaced T&P rockers with new S&S rockers, replaced cam 585, and thats when it started to sound...
Sounded like little marbles every once in a while at first, not all the time but as the days grew so did the noise. now being 8 months since the re-build, it sounds like a 1 pound coffee can full of marbles when its making it.....
I have removed the primary cover and checked both nuts thinking i left one loose when i put it back on.
i have re-shimed my cam to within .006 limit.
i checked every nut and bolt i touched during re-build.
The noise mainly happens when idling anywhere. I use to be able to rev the motor alittle and it would stop. It is not letting me do this as much now and i can hear it now when i take off too until it stops a few seconds latter.
Just fustrated that i cant find it. Any help would be appriciated guys....
