TIRE SEALANT
beano
Any one ever used green slime in tire?I just pulled a small nail out of my 250 and Im giving it a try.Ill let you know how it holds up.
PROFLYER
SWOLE
Don't think you're supposed to in motorcycles because it can throw the tires so off balance...not sure on that though. Either way, why would you risk it? Take it in and get it patched/plugged.
Fibersnake
Banjo Playing PsychoBilly
I would recommend that you take the tire in and get it replaced. Being on two wheels and not 4, taken all precautions to prevent a failure at speed can not be over emphasized. I would plug it if you have to, but only long enough to get it changed out properly.
Would stay away from the Slime by all means for not only are you risking it not working or failing at the most inappropraite time, a question to me would be what will that stuff do the nice billet rims both in the short term or worse show unknown effects later down the line??
Beside, if you were going to get a new tire, now would be the best time!!
bdmridgeback
Low Down Chop Shop
I would not use that stuff in my bicycle tires!!
It makes a mess inside especially the wheel.
On an nice hot day the stuff all runs down to the bottom and the tire will be so far out of balance it won't be funny.
Good luck
jimizee028
TRUE COLORS COLLISION
what did kenny used to say.....know when to hold 'em,know when to fold 'em....gotta love a gambler,especially one that is willin to put his life on the line!!!!!!!!!!!!!!!
erldawg
:eek: Many years ago in my former mechanic life I had to take a tire off a rim that someone put that crap in what a friggin mess. I would never use that stuff.
Take your ride over and get a new tire put on or have it patched.
I wouldn't put that stuff on my worst enemies tires!!
If you wanted something fast and easy would have been better just doing a old school plug. But alot of this debate has to do with where the hole is and how comfortable you are with a "repaired tire" on your bike.
The problem is that the sealant cakes the inside of that tire and rim. It hardends and is a BITCH to get off. Has to sometimes be chisseled off the rim. It will seal the tire but ruin it in the same token. The wheel/tire won't balance and when you go to change the tire you will have to take a wire wheel to the inside of the rim.
I tried to stay out of this but....... Don't use the slime. Makes it almost impossible to patch from the inside. If you want to drive around town until you get a new tire and the nail was in the tread area, put a plug in it. Replace the tire as soon as possible.
dogvet
Banned
Your mechanic is going to be pissed when he changes your tire!
I've worked at shops where they will pad your bill (we used to call it an "a**hole service charge) typically a 10% increase in the labor total...FYI
beano
If need be when I get my tire replaced Ill take the rim home clean it up and then have the new one put on. "Dont pet the sweaty shit".....I mean "Dont sweat the petty shit"
surferdude
dry docked
I got a nail right in the middle of my 300m and nobody would touch it. Had only 4k on it ... I tried plugging it but it wouldn't hold ... so I had to cough up the $340 to replace it and nobody here in Cottonwood AZ has equip to balance it ... good thing I learned about the Dyno bead this week ... order some and can't wait to try them out ... I wouldn't trust a patch or plug on a bike ... $340 is cheap for the piece of mind ... think about it ....:job:
Chopper Dave
SIICK!!!
yeah....you will be saying that when you go down!! get that shit out of your tire......why look for trouble when you don't need it....just a thought..
