Thanks Gas but I`m switching motor and coil mounts wanting to use dyna coilsYou just need a bdm replacement? I have one...
Cool. Just makin sure. Did you check out Vulcan? They make a nice set of dyna coils made just for them. instead of angled wire hook ups, they are straight out. Allowing you to re-use your current wires.
I looked at that what I didnt understand was the motor mount one half inch away from the frame which means it needs a spacer or use the original camel toe(not an option) or too tall and had to be cut down.Well I had to have a 45* canter put on the top leading edge of the yankee mount. It had a vertical edge sticking up over the face of the vulcan coil mount that didn't look good. I also had to have the bottom cut out to accomodate the key, and a new rear piece where it mounts to the frame. More detail and pics can be found in my Phoenix thread under customizing.
Ray your correct 3ohm will do her...The coil in your bike should be a Crane as mine is. I believe they are 3 ohms.
I had a whole new piece cnc'ed versus using the spacer idea.I looked at that what I didnt understand was the motor mount one half inch away from the frame which means it needs a spacer or use the original camel toe(not an option) or too tall and had to be cut down.
