cdogg556
You guys won't believe what's up now, so I have had my speedo doing some weird shit lately going off, coming on, going off again, fricking strange, anyhow I just figured that it's getting old and need's to be replaced, which still could be the case, so yesterday I am riding and all of a sudden for no reason the bike won't turn over, no power to anything, key on but nothing, I end up getting a tow (from out new member Bob! Thanks Bob!)home and I pull the bat covers off and look at the ehc fault lights when I turn the key on and they are all lit up and stay lit up with the key on, but still no power to anything, bat tests good, even tried to jump with my lithium jumper kit and nothing, so I am going through the flow chart and eliminating things and get to load testing the battery, well as soon as I put the multi meter on the terminals with the key on the fault lights went to normal! The yellow power light stayed on and the green light flashing, headlight cam on also, but no running lights or license plate light, but turn signals and brake lights work, so I pushed the run button and now the red ignition light comes on and the bike fires right up! Ok, wtf is going on? So I shut down and wait a few min and turn the key on and the lights look good on the ehc, same thing, headlight works but no running lights, try to start it and click, nothing and now all the fault lights are staying on again! Ok, so I put the M.M across the terminals and all the lights go back to normal again, put run and it fires up again! I am confused to say the least, the only thing I can think is the ehc is going bad, I checked the key by bypassing it with a jumper wire so I know I have it's ok, I uplugged the tail lights, tag light , speedo sensor, etc......even checked the green wire from the starter for voltage and it was good also, so now at this point what I have is everything works, it fires up but but I got no running lights or speedo at all, headlight works, turn signals work, brake lights work, wtf? I think it's the ehc, what do you guys think? I guess I'll just carry the m.meter with me so when it does it again I can re set it by putting it aross the terminals, weird! Anyway sorry for the long ass message but just wanted to explain exactly what is going on, thanks.
That's weird when you put the meter on the battery the EHC resets
I wish I knew enough about it to send you some help.
