Drdave427
Thanks Eric - I’m afraid of heating the hubs - not sure how much heat without damaging anything. I’m sure it’s the original tire I’m trying to get changed- I’ve got a really strong impact but having to use an extension to reach those DAM bolts takes the “impact” out of itYou got 5 Bolts on both sides of the hubs (10 Total), your wheel is threaded. Another good reason to change your rear bearings every tire change the bolts are RED loctited but you should be able to get them out without too much of a hassle. Maybe the PO never changed them!
Easiest way to do it is take both hubs off then take the bearings out with a press and then press in new bearings.
I thought I’d skip the bearing step but they feel like they have gravels in them
Sorry for high jacking Shannon
Thanks for your help
