rasdes
I've read just about every post I could find concerning tach issues, 2007 Pitbull, stock EHC, runs fine, checked every connection I could find...even replaced the Tach board with a new one, same thing. Turn signal indicators, high beam, neutral lights all work fine. Holding the throttle steady at around 3000, lights drop to 2000, then nothing, then 1500, up and down between no lights and 3000, never steady..... , very erratic..any ideas from anyone on what to do next is very much appreciated.
Forgot to add...... I also removed and cleaned the Crank sensor after reading many posts concerning this issue
Thanks in advance
Thanks in advance
