I don't have any leaks Cutty.....and not really that much top end noise either...but my rockers and heads were changed out also...its quieter now then it was before:up:I plan to use the synthetic now that I got 5000 since my "re-breakin" after my engine work...
I have seen a lot of recommendations to wait at least 3000 miles for the full break in.
Supposed to run cooler and smoother; but more susceptible to leaking, and more top end noise?
Everyone told me to have the motor broke in first...at least 3000 miles or more....I did mine at 4400 mileswhen is the acceptable mileage to turn to syn? got about a 1000 miles on mine and wanted to make the change to help with the temp. my buddies 04 chopper dropped 18 degrees with the change!
if you are still under warranty, do what the manual says so they can't deny you if you have a claim. otherwise, on the 2500 mile seems to be the norm. :2thumbs:when is the acceptable mileage to turn to syn? got about a 1000 miles on mine and wanted to make the change to help with the temp. my buddies 04 chopper dropped 18 degrees with the change!
Good advise.if you are still under warranty, do what the manual says so they can't deny you if you have a claim. otherwise, on the 2500 mile seems to be the norm. :2thumbs:
