Jersey Big Mike
100K mile club
Well I suspect you lost a little less than that in reality -- you likely lost some on disconnect and some when you reconnected to measure again.I went stock pressure, per the docs. 175 on rear and I think 365 up front. I had to adjust to get it back up to spec.
I lost 50 PSI on detach on the back and 25 up front. So pump up +50 on rear and +25 in front to get it right.
Also, hope that's a typo about front and rear.
FOURNALES SUSPENSION SA 23, ZA Ribaute 31130 Quint FrancePhone. : 05.61.24.75.25 Fax : 05.61.24.75.25 Web : www.fournales.fr Mail : infos@fournales.frHD SOFTAIL from 2000 onwardINSTRUCTIONSThe PAN-CRUISE “EVOLUTION” oleopneumatic shock absorbers are delivered fully inflated by the factory in Quint(France) and are ready to use without any further adjustment.
They have been tuned for an average load and will accomodate one or two average persons (70/90 kgs) without need for adjustment. The factory set-up also aims at maximum comfort.The P1 pressure (P1 is the main spring pressure supporting the weight of the bike and its load) has been set at 27bars (395 psi). The air valve is situated at the rear of the unit. The P2 pressure (P2 is the ride height adjuster pressure) has been set at 10 bars (145 psi) giving the bike the sameride height set by the HD factory. The air valve is situated at the front of the unit.
