just throwing a thought out but, just because an item is new, don't assume that item is good. been there-done that.I will double check leaks tomorrow...
Ignition and switch should be good. New thunderheart asm 5012
I hate that when the nipples go badSurging, falling on it's face can be caused from..
-Lean condition (intake seals,plug on carb nipples bad)
I would think a leaking intake would shutter no matter what air cleaner? But the shutter goes away with a change of air cleaner DESIGN = The art of air flow is not happening to this dual daully does shutter, right?To check for intake leak, start bike up, let run to operating temp, at idle spray(from intake side) both front and rear intake seals with brake/parts cleaner...if idle changes at all, you most likely have an intake seal leak.
So like I said, I am reading the abstract. And so as not to single out any one abstract, didn't NOLTT mention someone will keep telling you to keep jetting..... OOPS! I see you did = Edit.EDIT: I just re-read the whole thread... I see you have already changed the Air Bleed........ sorry.
:2thumbs: you are getting there!Took it for a quick scoot today.... seemed better but didnt get chance to open it up. Got a little lag on hard acceleration , but prob just accel pump adj...
Will try again in a week when i get back from work
