strart button
mml03102
I posted this before but anyway I usually have to push the start button and run button together to get it to turn over , I always push the run button first then start but usually have to push them both together , Im worried about getting stranded somewhere , brand new braille battery all wires are connected properly and tight.
Has anyone had this problem before?? I would appreciate your advise!! :bang:
mml03102
I am wondering if thats what it is too, going to take it apart but doubt its something I will be able to look at and see the proble, but wont hurt to check it out I need to change the grips anyway
Dakotabos
Might be worn.
Pop the seat off,
turn the key on,
THEN hit the off button,
THEN hit the run button,
(1 red light on EHC should come on),
Finally hit the start button.
Let me know :cheers:
mml03102
Yes the red light goes on when you press the run button and nothing else goes on when you hit the start until you press them together then you get the green light, go figure?
Im going to re configure the wires on the battery , aI am using all four ports now but will re arrange the wires and see what happens , doubt thats it but what the hell,lol
mml03102
I just re arranged the wires on the battery 2 on top and 2 on the positive side terminal and all seems to be fine!!
twilliams111183
I had the same issue with my pitbull put a push button on the starter and use that all the time. Don't put your self through all the trouble of replacing the switch board on the controls it will just happen again. Or you can just buy new controls the ones on it are crappy. I would still put the push start on for back up or everyday use. Worked for me should work for you.:up:
twilliams111183
P.S. don't go cheap if your goin to use it every day great push start is $70 and durable plus it was my first time putting in a push start it was easy.
mml03102
I just checked it out there marked down to 61 dollars . I imagine they come with directions and also I imagine the key has to be on?
mml03102
Thanks for the advise I really appreciate it!! the way its been acting it will be great to have a back up!
