Sticking shift
MommiesToy
'05 Chopper
When the bike gets hot (normal running temp) the shifting starts sticking.
I have to use my toe to pull the shifter back so I can then shift down.
Its like stuck forward. This gets old really fast. Love the bike but this is not good. I've adjusted the shifter and its works fine up until I've ridden 8-10 miles.Does anyone else have this and if so hwo to fix?
Thanks
clean and lube your heim joints on the shifter linkage or completely replace the joints with some that have brass inserts. they are notorious for sticking.
P8RIOT
Yup - classic problem with the heim joints. Next time it sticks, reach down and rotate or fiddle with the shift bar. You should be able to wiggle it free, and that would identify the problem. Lube 'em liberally, or replace them.
don't use a wet lube like wd40. try to use a dry lube like cable life or a little bit of graphite. wd40 will just attract dust faster.
BubbleHead
Big Dog Biker test account
I had the same issue. Big Dog replaced my hiem joints in Myrtle Beach and smooth as glass ever since. Do your self a favor, get them replaced no matter if you buy them or BDM does, you'll feel a lot better once it's done.
Chopper Dave
SIICK!!!
I had the same problem last summer.....my dealer replaced my heim's ....under warranty:whoop: haven't had a problem since....
MommiesToy
No clutch issues. I libberally cleaned with WD40, then lubed with lithium.
Shifted extremely smooth. If this comes back, I'll replace.
Thanks
LamboV12
I had that problem - heim joints fine - forward controll had "zero" grease in it. Lubed it and good to go since then.
MommiesToy
Woodbucher - I've done all kinds of searches and cannot locate or find male hiem joints. Harely only sells the female heim joint. I ordered a chrome plated one from JEGs and it was stiffer than my existing problem joint. Tech Supt said thats how they are - more for automotive applicaiton. So...where can I get these for my Chopper? Thanks
RRRUFF
Bryke Racing LLC
or go to eBay and put in Item Number 330214489003
5/16 X 24 Male thread one left hand and one right hand
