BubbleHead
Big Dog Biker test account
I have been having a small sporadic issue with shifting in to second gear. It's like every once in a while when up shifting from 1st it goes in to netural instead of second. I know I'm lifting my foot hard enough to get it to go in to second. That is the only gear there is an issue with. If I double clutch it, then it goes in to second ok. Like I said though, it doesn't happen except every once in a while.
Also very rarely it will drop back down from 3rd to second on a hard acceleration. Is it possible that the shifter pawl located on the tranny needs to be adjusted? I'm looking for suggestions here or anyone else that may have this issue occur.
also, besides lubing the hiem joints, make sure they are parallel to each other for less resistance. shouldn't be out more than about 5 degrees. :2thumbs:
Scuba, wait till the boys at myrtle beach get a load of us, "the twins" going down Ocean Highway and 17 riding next to each other. Look the same, sound the same, We'll create some "double Takes' and neck turning !!:roll:
