smokeing out of front cylinder
nickr
me and my friend went for a ride yesterday and after about 60 miles it started smokeing out of front cylinder and makes a knocking ticking sound in top end. only time it dose it is when i come out of a right turn.
outdoorsman26
well could be valve seals, poor rings, leaky gaskets, poor oil flow causing too much pressure. the knocking and ticking sound is prolly your rockers and push rods cuz they aint gettin oil prolly not a good idea to ride it any more til you get it figured out!! if i remember there was another guy that had this problem last yr???
nickr
ya i dont plan on rideing it tell its fixed a guy told me it sounds like valve stem oil seals or valve guides.
outdoorsman26
how many miles you got on her?? might be a good idea to go thru the cyl's as well seeing as you have to pull the heads to do the valve job!!!
Sounds like ~ a wrist pin clip took off out the right side piston wrist pin hole ~ clip goes up and down for a few strokes ~ scores whatever to the piston, ring, and cylinder wall ~ she eventually is down in the crankcase somewhere ~ the wrist pin is now floating against the wall making or taking out two touch points is the wrist pin to wall ~ what the clip did at what miles it took off ~ here is either a long or short variable ~ is the pin's clip took out the rings and it is now smoking ~ the right turn knock is the wrist pin floating and then back again = Never start this bike ever again ~ Start tearing down!
And if that wrist pin put a groove in that cylinder wall where you can feel it? It says, you cannot create or destroy what is floating in that oil ~ is throughout the whole oiling system from bag to pump gears to crank bearing surfaces is ~ what a mess you hope you cannot finger a nick off that barrel or she is a time bomb you just change the top end, drain the oil, found the clip or most of it... You wanna sell that puppy? It's a part bike you do not wash every last part, nook, cranny and then some.
