LA_Dog
Go Fast, Go Faster
you'll know if it's peeling by looking inside the tank with a flashlight. it is plastic looking stuff- it will clog up anything. tank may or may not leak without a liner- these Big Dog tanks were all hand made and have a lot of welds / bondo. welds are usually rather porous and would at least seep gas vapor / cause paint to bubble and lift. there are places that can strip and re-line the tank for a couple hundred bucks and without harming the paint job. or you can "DIY" but I have to warn you it is a messy, toxic, labor intensive process. if the tank is not cleaned properly the new liner will also fail. I love DIY but this is a process I would happily pay to have done if needed. (and yes I had mine done- was peeling- tried DIY - paid to have it professionally done)thanks for the heads up , as the liner goes away , I assume the tank will still
hold gas ??
I do have a large filter just after the petcock, and the petcock has a screen ..
btw the cx500 only has 28K and is a parts go-getter
( IT never needs any heh) )
Anyway just keep an eye on it- it will peel eventually, they all do.
