TCAL....actually it's my front cylinder
(rod bearing) thats shot and not the rear
the rear is fine
My cylinders are fine...but I am going to Bore them .010" over just for the hell of it....Heads are in great shape too....but i'm doin them as well....doin the whole motor while its down..
Rebuild heads new valve guides & seats..grind & lap valves $75 per/head.
Bore cylinders $70 each
Piston Set +.010" $150 for the set...
Lower end The way its looking now the lower end is tight except front rod bearing....and both wrist pin rod bushings are worn...need to replace...havent figured out whos going to balance the lower end yet.....or to just run it like that......+.010" pistons can't be that much of a weight gain to the standard....$100 for rod bearings & bushings..
