Five Five
Well I have been hearing a clinking noise front cyl for the past 100 miles....thought it was my compensator sprocket assy...changed out the whole primary drive with a spare I have.....didnt fix It....Stator/Alternator good....
Thought WTF pull the top end check rockers all good...pull heads...all good....cylinders pistons show normal wear...
I'm thinking cant be Rod Bearings it was just a mild "Clinking noise" and not a "Knock" hell I only have 28K miles on the motor.....change the oil every 2000 miles
Well I put my hands on the Rod check for up and down play...Crap !!! there is about .100" play ????
WHAT CAN CAUSE ROD BEARING FAILURE ??? AT 28K ???
