Gdog
Took me about 4 hours but I rewired the EHC in my 2006 K-9. I used the stock controls. Had to use a bunch of relays due to the negative voltage from the controls. Everything works but the turn signals. I am going to install a delay module for them. I was able to use the existing ignition switch. I only hooked up the low beams. I used all bosch standard 12 volt relays. A little big but they work great. I was too impatient to wait for the wire plus system!! At least I'm back on the road!!
