Chopper Dave
SIICK!!!
yep..Chaingunner is also running the Braillehey, so far so good !!! real good !!!
I think you can see all threads here about the Braille with no complains at all!
the thing rocks !!!![]()
alhall, mine too is running with the original 04 starter!!!My bike is a 2004 and it still has the original starter and I have been running the braille so far this whole season with no issues at all.
I have the Interstate 310 CCA battery....same size as stock...and is a AGM battery.....
I have the one pictured...part # CYTX20HL-BS
Interstate Batteries - Every Battery for Every Need
I didn't even get a year out of that battery HipSame battery inmy Scoot..!!! Problem free...!!!
You have replaced a battery in an '09 already?? My stock '07 is still going strong (probably just jinxed it). What is a typical life?You guys make sure to post up here if you have starter trouble after replacing your battery please. My dealer seems to be under the impression that even though the BDM starters are prone to problems that my using the Braille might have caused my starter to go bad somehow.
It wasn't that the Interstate went bad on me, it just never started the bike all that well so I figured I'd try the Braille (B2015) with it's better CA and it was a noticeable difference.You have replaced a battery in an '09 already?? My stock '07 is still going strong (probably just jinxed it). What is a typical life?
I have had a couple batteries in my 07 Bulldog. BDM replaced one when they had it a few months after I bought it along with just about all the other electronics. I also have purchased a new battery. I bought one from Harley and put in. I wonder if the EFI bikes put more stain on the electrical systems than the good ole carb units....You have replaced a battery in an '09 already?? My stock '07 is still going strong (probably just jinxed it). What is a typical life?
I think in my case it might have more to do with the larger engine, higher compression, and bigger bore then the others but I'm sure the EFI doesn't improve matters any.I wonder if the EFI bikes put more stain on the electrical systems than the good ole carb units....
I would replace the battery every year or two at max myself.
Neil
Oh boy, that 4 cu in must really make a difference. Your motor is probably easier to start than ours cause it's a square motor with a shorter stroke.I think in my case it might have more to do with the larger engine, higher compression, and bigger bore then the others but I'm sure the EFI doesn't improve matters any.
your dog is running!!! who cares about what the "professionalelectromagneticpulsingdealer" said!!!It sure worked better for me as well but my dealer is under the impression that you have to be an engineer to make such a crazy "assumption". Me hearing it start right up without the straining and other problems of the stock battery isn't sufficient enough of a difference in his opinion.
Oh that's ridicules. My bike is going on 5 yrs old and had nothing but the poor little BD batteries in it and has provided me many trouble free miles. If you take good care of it, check your cables weekly, keep it on a battery tender and don't leave your key on when you stop and such it will provide you many trouble free miles.just had it in for service and they said it because of the big motor.
