john sachs
You don't need to readjust.What if you had a stock Harley motor without adjustable pushrods?What would you do in that case?
Simple solution.
Get cylinder on TDC COMPRESSION.
Install p/rods
Drop rocker saddle with rocker arms on.
Be sure p/rod ball ends,are seated in the rockerarms.(male to female,kinda like sex).
Tighten SLOWLEY,and evenly,a little at a time,giving lifters a chance to bleed down.
When tight,and you can turn each p/rod by hand,go to the next cylinder,and repeat.:2thumbs:
See,Brad was fairly right.
John
OH....
Be careful with long rockerbox cover bolts in the valvespring area.
Simple solution.
Install p/rods
John
OH....
