The manual says to remove the oil tank but I'm letting you know you actually don't have to. You don't even have to remove the rear fender. Everything you are about to do, I've done. The reason it says to remove oil tank is to get to pivot shaft, you can do the same thing by removing the exhaust, clutch push rod cover and starter. A hell lot easier than the oil tank and the lines.
