rear tank mount
semi
Can someone tell me if there is any adjustment associated with the rear tank mount ? 2006 K9. Can it be raised or tighgtened ? My Tank has become loose at the rear and has about an inch of play. Top is solid. Do I just need to replace and if so where the hell am i gonna find a rear mount. Thanks for the help.
Had mine replaced......used one from a Harley. Had to modify it a little, but it worked. Can't remember which one we used. Take the old one to a Harley dealer or contact one of the vendors on the site and see if they have one or can tell you what will work.
Oldskuul
Yes it can be adjusted. Take the tank off and you will find a rubber pick on a stud with a locknut.
When you do the adjustment you will need to put the tank back on and tighten the front mount to check the play a couple of times.
Henry
Mine was jumping around quite a bit also.
Sent from my I897 using Tapatalk
Oldskuul
Mine looked a bit worse for wear also, the rubber is a bit gooey, I'm looking up the price now.
